257 Roberts
Hey gents. My 1955 TO-35 occasionally develops a sputter and miss under load, the classic weak ignition symptoms. I'm thinking my coil is marginal and needs to be replaced. The tractor is 12v and was converted to use an alternator before I got it. I put a Pertronix kit in the distributor. Cap, rotor, and plugs are new, wires were replaced a couple years ago and are clean and secure. I checked the coil (internal resistor), and got 5 ohms on the primary, and 5.8k on the secondary. Seems to me like it should be around 3 and 10k instead. What say you? I'm thinking this coil is marginal and ought to be replaced before I do anything else. Thanks!
