maxazillion
Fellow Fergy owners:
I have a 12 volt conversion question. I recently converted a TO 30 that I own over to 12 volts with a Delco 10 SI 3 wire alternator. I ran the P1 wire to the lights post on my ignition switch since I did not want to mess with a diode or idiot light. My question is if I connect my headlights back up can I run the lights wire to the lights post on the ignition switch also or do I have to connect the P1 wire back over to the ignition post with a diode. Thanks for any responses.
