Re: Won’t stay running
old
08-06-2018 15:15:42
Turn the gas off, the TAKETHE LINE LOOSE AT THE CARB. Then take the gas cap off and if you have a compressor blow air into the line which will then blow what eve junk that is causing the problem out of the line and sediment bowl. Yes in the future it may cause a problem again but many times it takes a long to time to do so. If you do not have a compressor you can put a plastic fuel line on the line and blow threw it to clear it also. BTDT to many times and gas sure does not taste good. LOL
cmatus
08-06-2018 15:22:25
 Re: Won’t stay running in reply to old, 08-06-2018 15:15:42
Took the air compressor to it and now it flows good. Now I just need to get a new gasket for the sed bowl.
old
08-06-2018 15:31:11
 Re: Won’t stay running in reply to cmatus, 08-06-2018 15:22:25
If you have a local O'Reilly's the fuel strainer gasket is part #398. That is what they called a sediment bowl. I keep 2 or 3 on hand all the time. When I buy them I buy every one they have
