FE35 Diesel Lift Pump
JohnPom
I brought a lift pump from Queensland Tractors (they have very good service) and had to return it as it was not right for my 23C.
On mine the lines seal by seating on the bottom.
Theirs sealed by the threads being tapered on the fittings.
So as mine are copper lines, which I don't want to change, where can I get the right one?
Ta,
John
Also as the reason I'm changing it is because the arm for manual pumping is broken off.
Can I repair it?
Ta again,
John
You might want to try Agriline Products in the UK - they seem to have a good selection of 23C parts. They show 2 different types of lift pumps. I've contacted them to ask questions prior to my orders and they were very helpful.
After 60 years, you better get used to 'improvising'. These aren't high pressure lines, so you can fit adapters that are basically a nylon hose..... I just noticed something you mentioned- I will bet the copper wasn't an original item, your tractor?? not the new pump?? is what's not right?? better ask around...that shop should know...
