TO 30 Cant Stop Lift Arms From Lifting
guysradios
New User
Just finished restoration on a TO 30. Disassembled hydro pump, cleaned and inspected. same with lift arm cover and assembly. Upon start up and engaging pump, the lift arms raise when I let out the clutch. Quadrant lever position has no effect. Arms lift to the point where they will bind on the bottom of the axle housing and bend. What am I missing here ???
You put it together wrong. . . .
Sounds like at least the position lever is not attached internally. Did it fall out?
(quoted from post at 14:14:20 07/24/18) You put it together wrong. . . .
Yep, that's what happened, got er fixed now !
