Ferguson TO-35
JCP NC
My son just bought a Ferguson TO-35,1955 model I believe. The wiring harnesses that we have found cost a small fortune.
The harness for the Massey Ferguson 35 is cheap.
My question will the one for the Massey Ferguson work on his tractor?
It has the continental gas engine.
Thanks
Jack
Did you look at Agri- services? Their site is wiringharnesses.com. Absolutely perfect harnesses and look like Restoration quality. You can
download their catalog. When you call to order they will make sure you are getting exactly what you need. I have bought six or more
harnesses from them for TO30?s, 35?s and a 9n and Farmall A.
The harnes for my TO35 was made to accommodate an alternator and regulator that I also got through them. Talk to Jim and you will get
You can go to fergusontractors.com/fena then resources--wiring diagram and wire the
tractor you self. That's what I do and cost very little. Takes about 25 ft 16 ga
wire.I use 14 ga. on coil from regulator.It's easy just print diagram and follow it.
It will show fuel gauge but just by-pass it.
