steve-in-ga
I'm sort of stumped on this one. My to-30 will not start up. Usually its one of my most trust worthy tractors. When troubleshooting the issue, I pulled #4 plug and grounded it and have little to no fire at the plug. Pulled #3 plug and the same thing. Pulled the wire coming from the coil off the distributer and ground it out and have a fat blue spark. Correct me if i'm wrong but that should signify the points and condenser are good, right? That leaves the rotor, cap, wires and plugs. Went and got my spare set of each and installed them and still have no fire at plugs. Made sure all wire connections at cap and plugs were clean and good. What am I missing?
The battery finally ran down so much I had to stop and put on the charger.
thanks for any help
steve
thanks for any help
steve
