TO-20 Hydraulics
cstory
Using 1951, TO-20 and post hole auger digging post holes, auger hung on root when I was raising auger, loud pop then no hydraulics. Thinking pressure relief or safety valve ....All help appreciated.
Has both the HYDRAULICS as well as the PTO FAILED?
Something may have failed or Coupling has disengaged?
Drain Oil,side plate and view the internal organs:
Bob...Owner operator TEA-2 Ferguson:
PTO shaft still works/turns, I can bush hog no problem just hang bush hog off bridle chains. Hydraulics is the only issue. When hydraulics worked, could stop Tractor and leave disk in air for hours no leak down.
there is a good chance the hyd lift cylinder broke loose when auger pulled down. To find out take of side cover and start tractor with lift levers in up position. If there is a lot of oil coming down from lift cover area, that's probably the issue. The pop is what makes me think that.
Let us know what you find.
Jim
All service manuals and Part's catalogues I have purchased off of e-bay.
I only purchase ORIGINALS:
Owner operator TEA-20..
Bob...
We broke the arm that rotates the rockshaft cultivating with 44 again. The arm the hydraulic ram pushes against. Dad backed up the tractor 1/4 mile to the house. Never broke it again.
