TractorLinks.com
Show Parts for Model:
TO35 rear PTO shaft
Mikeroche56
07-08-2018 17:09:44
Anybody used a Speedi Sleeve to repair the oil seal area on a TO35 rear PTO shaft?
54FergieTO30
07-09-2018 19:45:14
 Re: TO35 rear PTO shaft in reply to Mikeroche56, 07-08-2018 17:09:44
Drip not drop, can't type.
Mikeroche56
07-10-2018 11:59:23
 Re: TO35 rear PTO shaft in reply to 54FergieTO30, 07-09-2018 19:45:14
:) Thanks, I have a sleeve and 2nd new oil seal on order. Mike
54FergieTO30
07-09-2018 19:43:46
I used one successfully on a TO30 about a year and a half ago because the shaft had grooves worn in it. It s been perfect, does not drop a bit. Used a new seal of course..
Mikeroche56
07-09-2018 13:16:35
Or asking a different way, has anyone had a leaky PTO shaft that wasn't fixed by only replacing the shaft oil seal and outer retainer Oring? If so, how'd you do it? Thanks!! Mike
Steve@Advance
07-09-2018 15:48:39
 Re: TO35 rear PTO shaft in reply to Mikeroche56, 07-09-2018 13:16:35
I haven't had to use the sleeve, but it is an option when the seal surface is worn.
I did have to redo the seal once. Put in a new seal, it leaked. Took it out and looked at the seal, it was made wrong! Looked like when it was assembled the rubber part was not centered in the steel part. Never seen that before or sense. But might look at your's, no telling how many were made that way before it was caught.
If your shaft has a groove worn where the seal runs, a common trick is to not drive the seal as far in so it runs on a fresh surface. Or sleeve it.
Mikeroche56
07-10-2018 11:57:57
 Re: TO35 rear PTO shaft in reply to Steve@Advance, 07-09-2018 15:48:39
Thanks, good info.
