Ferguson hay rake
Jflaw92
New User
I got a 3 point hay rake. The one wheel is rotted out, does anyone know where to get a new one if there's any out there? And also what years was they made? Thanks
If I remember correctly, I got two of the solid rubber rim/tires (no air needed) from harbor freight and put on mine several years back. The fit on the axle bolt isn't exact but they work good for me for the little hay I make each year.
Ferguson supplied many hay rakes, what is the part number on the tag? Understand these old implements are no longer serviced, meaning parts are no longer made nor available for them -for the most part. Some standard parts like bearings and bushings and other hardware can be purchased but not at any M-F dealer. If wheel is steel, and I think it is, you may have to find another unit and buy it then swap out parts. Option #2 is to take the old one and/or the good one to a blacksmith, the Amish communities usually have one, and he may be able to make a new one. Option#3 is to contact George Bradish Tractor Parts or Scott Deppen at Sweigard Bros; and see if they have one in their yard. Whatever the decision, it ain't going to be cheap.
Tim Daley(MI)
