My lift arms have never really had the power I thought they should but had enough lift to do what I needed to use them for so I have not done any trouble shooting. Recently they barely lift themselves empty and cant lift an implement at all. I just did a fluid change when I had to split the tractor for an input shaft seal, shortly before they started deteriorating which may or may not be related.
Well I removed the PTO shaft cover to inspect the filter and there I found no filter. I felt around with my hand in the oil and found no apparently place for a filter. So I drained the oil I still don't see it. I looked at pictures of pumps online and mine appears to be different although its a bit hard to tell looking through the access plate comparing it to pictures online. I can read a part number on the pump if I am reading it correctly I believe it says:
1BD 931 M1
This number does not correspond to anything I find online.
One more thing when I was feeling around for the filter I found a a piece of metal laying on the bottom that I can not identify.
Here is what I see inside the access plate sorry for the poor lighting/picture quality...
Here is the piece of metal I found
1BD 931 M1
