Scarboroughseadog
New User
Howdy Folks! I went to start up the old girl after a while lying idle. Turns over enthusiastically with the new battery. No spark to plugs. Tested ignition with volt meter, works OK, getting 12v to both sides of coil and out of the top of it. Spark plugs themselves are fine.
Must be the distributor? Not sure how to test that- any advise for this novice? Not sure how I go about checking the points.
Can I take the lead off the top of the coil and hold that to the chassis and turn over (ignition on) to double check that gives a spark to confirm it must be the distributor?
Thanks
Thanks
