I have posted previously that the 3 pt on my TE 20 has started to not want to go back down after lifting up. I still have not had a chance to pull things apart but one thing I did notice is that the oil level is low.
Will this cause the problem? I ask because I don't want to add oil to just have to drain it out to take the pump out. When I encounter the condition that will not allow the arms to go down, the draft control lever is somewhat springy in that if you are pushing it all the way down it will not stay down.
Thanks
Ryan
Thanks
Ryan
