Oil filter barrels TEA20
Crossroads
New User
Hi everyone, I have a 1952 TEA20 that has a inclined type ?Y? oil
filter unit and I would like to know if the barrel goes on/off as a normal
thread i.e tighten to the left loosen to the right. I would like to know
this so I can ensure I am turning the correct way. Thanks Crossroads
Thanks Richard for your email!!! Good point on lefty and righty!!!!!
I have tried to remove the barrel with a oil filter wrench and cannot remove it not sure why, would you have any recommendations. For removing the barrel, I am afraid of damaging the barrel. Thanks Crossroads
You don't turn the barrel Crossroads there is a long bolt that goes through the barrel and filter and screws into the filter head . Look at the very bottom , unless the bolt has been welded in to the barrel there should be a bolt head visible there . Sometimes this area leaks and instead of renewing a simple rubber seal the owner welds the bolt into place , a silly practice .
The seal inside the rim of the filter housing head makes it very difficult to turn the barrel as it is inclined to stick and weld onto the rim . Be wary of too much force , the head is only cast alloy and can be fractured if twisted .
(quoted from post at 14:24:13 05/03/18) It is not threaded. Try undoing the bolt at the bottom of the barrel.
Hi John, my unit is not bolted at the bottom the barrel is a thread type but I can’t seem to budge it not sure what else to do. Thanks
Hi Charles, my unit is not a bolt type but a barrel that is threaded, however it seems I can’t thread it off for whatever reaso. Looking for some advise on removing it safely. Thanks
One of several PARTS TEA-20s I have:
In my spare time I designed a Thread on Oil Filter attachment......as well as a remote block locator:
True Ferguson Officiators shall cry bloody he_l........
Bob...Owner Operator TEA-20 and other colored Tractors....
Thanks Bob, this is very helpful information, this should solve my problem. I certainly like the conversion made the the FRAM filter, good work. Thanks again Crossroads.
A UK built TEA 20 will have had this type of fastening on the[u:3cd248a141] inclined filter[/u:3cd248a141] housing .
If it does not have this bolt it is possible that the housing and filter head have been changed at some point .
The bolt that goes through the top of the hosing head as shown by John Deere's photograph is normally a feature of the earlier six volt tractor vertical filter housing as is the disc topped dip stick . Perhaps these are variations peculiar to the Nth American and Canadian markets .
Good evening Charles in Aus.....This little Beast "TEA-20" Standard Engine, sure had a selection of different adaptions depending on the Country of destination.
I've only seen TEA-20s Made in Coventry England that were shipped to Canada......
Thanks for sharing this information..
Bob...North Western Alberta Canada....
Always welcome Bob , the amount of information you take the time to share deserves some back . :)
An exploded view of the inclined filter used on 12 volt TE20s and FE
and MF35 tractors .
(quoted from post at 10:27:04 05/03/18) Hi everyone, I have a 1952 TEA20 that has a inclined type ?Y? oil
I have a 65 w/ same. I used a filter strap wrench, you are unscrewing the barrel, think of it as a bolt. looking from the top down or mount it unscrews clockwise. mine was super tight hence the strap wrench.
(quoted from post at 10:57:01 05/04/18)
As previously said, you should not try to turn the external barrel. Loosen the center nut first. You will only damage the o-ring by turning the barrel.
Was there any sort of a washer used between the bolt head and filter casing, mine does not appear to have one.
