TO-30 weight ?
CKain(MI)
I looked up the tractor weight on 'tractor-data.com',
it listed the TO-20 at 2500 to 4400 (about).
Thats a large range. Anyone know what the weight of
a 'naked' TO-30 is. (no loader, no fluid in tires)..
Thanks.
(quoted from post at 17:16:45 04/17/18) I looked up the tractor weight on 'tractor-data.com',
Thanks.
My manual says 2376 lbs-dry. So I presume that means no oils or fuel. So 2500 is pretty close to normal.
Without looking at this one I know they list empty weight and for different tests different loaded weights to get maximum drawbar pull as an unweighted tractor the tires will spin without giving max pull, and they say tires need just a bit of slip so over weighting you loose drawbar pull. So the heavy weights are a loaded in different ways tractor to get mak drawbar pull in pounds. I had a TO-30 for a time with fluid in tires. Needed the cast as well that I did not have. They say you cannot use anything except a 3 point plow with them but mine was bad so I used a John Deere pull type behind it. Up to about 2/3 on gas did not notice wheel slip. open the gas and heavy wheel slip with no increase in ground speed.
Don't know the answer to your question but I know what mine weighs. I have loaded tires above the top of the rim. I know from rolling the valve stem and frost-sweat line on tires at times. I'm 200 pounds and a Ferguson 2 bottom plow. The tractor weighed in at the tractor pull at 3832 pounds. So take 350 to 400 off that. Remember that's with 3/4 loaded tires, So around 3432-3482 pounds.
2 loaded rear tires add about 600 lbs. So dry and naked would be on the money around 2800 more or less.
(quoted from post at 03:30:35 04/18/18)
My bad. The weights I gave you were for TO 20.
