guitarfule
New User
I'm working on a TO 35. The hydraulic pump split. Went to install the new pump and put the pto shaft in and the pto shaft will not slide into the hydraulic pump needle bearing.
The pto shaft is all the way into the housing but I come up about 1/4 away from the hydraulic pump shaft. I got the new pump from all states ag, they said it would fit. Problem
is when I removed old pump it was in 2 pieces and I'm not sure if the shafts should attach or not, sure looks like they should. See attached picture.
