Pics of my to-20
bones774
I just wanted to post a pic of tractor I picked up over the winter. Thanks for help from everyone.Anyone sees anything out of ordinary or suggestions to improve i'm open. thanks
Yes, the belly mower was a big reason for purchase. I thought it's a lot more compact than having a brush hog hanging off back. If the belly mower does not work out I would probably be willing to trade for a finish mower if I had to.
I learned to drive tractor on a Farmall Cub with a belly mower - just be careful, that mower will push you along while it winds down -
No they did not. I've asked the seller to call me if he finds that stuff. It looks like they would not mount as is with the pulley in the rear. I'm trying to figure out how to attach rear tow bar. The mower deck does not look like an easy 1-2-3 removal process. any suggestions appreciated. thanks
Because of the amount of grease and grime around the grease fittings I have to think that has been greased quite often and taken care of.
I have exceptional service records with the tractor, one reason I bought it. Wasn't even starting when I went to inspect it but it was so nice with records to prove it I bought it anyway. Threw a new 6v battery, drained gas and flushed line then sanded points, it started right up.
Good morning:
Great looking combination Ferguson /Belly Mower......:)
I own a Ferguson TEA-20 and a belly mower. My plan is to design / attach mower as per yours. Any chance of you snapping several pictures, so I can pick up some ideas?
Bob..Owner TEA-20....MF FE 35 X and other colored Tractors
