TO30 key switch
pomester
Question about the original key switch for this tractor - it is a three position switch? off-ign-ign/lights? Is/was there a plaque behind it with labels? - was it a 'two pronged' type of key like I've seen on other MF's? anybody have pictures?
Thanks
David
PS - I am disappointed in the 'complete overhaul gasket set' sold here and elsewhere (TISCO) - no vent tube gasket, no o-ring for the distributor, no pick-up tube seal for the oil pump, no oil filter bolt gasket...I did not expect to have to pick up these pieces separately, it's quite a bit of money w/shipping and fussing and waiting - FYI, beware your next overhaul
The key switch on my TO30 is a 4 position switch. Off-On-On with lights- Lights only. The key is a 2 prong and the indicator is a plate that goes behind the switch.
My dad bought that tractor 4 months before I was born. It has had an engine rebuilt, replaced the pinion shaft in the transmission, a broken axel, and has had a Sherman transmission adapted to it. I used it just 2 weeks ago. Here's a picture of the key for it too.
