I have a Harry Ferguson T0 30 tractor that has been converted to 12 volt operating system replacing the magneto.
The tractor would not start so I took off the distributor cap and the points were really burned. I replaced the old points, condenser, and rotor. Tried to start the tractor and nothing.
When I remove the distributor cap and try to start the engine there is no spark at the points.
I checked the spring on the back of the resistor and it is intact.
Can this be the coil? or voltage regulator? If the coil then do I purchase one without an internal resistor.
thanks
robert
thanks
robert
