William Fissell
hi, all,
is the front bolster cast iron or cast steel? I can grind on it i guess but the hive mind might know better than my eyeballing the sparks.
the axle pin was unsurprisingly worn but the bolster is pretty egged too. if its cast steel ill probably weld in a sleeve bushing. if its cast iron im a ill less certain. when I disassembled it there were several sleeves and bushings all kermunged on each other.
thanks
thanks
