TO30 / 9n parts swap?
JJHess
I'm in need of a few parts for my '53 TO30. Namely fenders, 3pt hitch parts, seat & steering wheel. I know of a 1944 9N that has a bad engine but all the parts I need for my Ferguson are there and in great shape. The guy will sell it for a very fair price but I'm not sure if the parts I need will swap over. Any idea about this? I'll just part out the rest of the 9n when I'm done with it. Thanks
Everything you said should swap over but I don't remember if the TO30 has a spline or keyway steering wheel. The 2n should be spline, later 8n keyway. Easy enough to check yours and take a wrench with you and pop the nut off to make sure.
sounds like you need my ferguson parts book,it has the to30 to20 te20 and ford parts cross over,its a old book has 150 pages,good for seeing what parts are the same and different on all the models,let me know,I'll give you a good deal.
The Harry Ferguson Parts Book (FORM NO 693 041 M2) indicates several parts that are interchangeable..
This Parts Book came with my TEA-20 when purchased in 1974..
I purchased another of the same manual off e-Bay...$$$$$$ well invested...
Bob. Owner Operator TEA-20 and other Colored Tractors
Fenders will bolt up but are different in the angle. Steering wheel is different, Fergy is a keyed slot. Don't know about the shaft diameter. 3Pt should all work just fine. Seat will bolt up.
Hyd pump is the same.
All the parts you mention you need, I believe will fit including the steering wheel. I have a steering wheel from a 35 on one of my 9ns. Ford 8n steering wheels will not fit.
