engine serial no.
That tells me that is a TEA 20 Ferguson tractor. TEA 20 means T=tractor, E=made in England, A=the engine is a Standard Petrol engine, and it is the 85mm engine.
The suffix EVR at the end of the serial number indicates that this engine has Exhaust Valve Rotators. I have the same suffix on my engine and broke a valve spring several years ago. While taking off the valve cover I noticed small ball bearings laying in the oil on top of the head. I picked up all the parts but could find nothing in the manual about them. I contacted John(UK) and he was aware that in the late year engines (1954) some were equipped with exhaust valve rotators as a test for the new 35 engine. He was not aware of the engine suffix but found out about it through research. He requested that I take photos and measurements which I did and sent them to him. He tried, unsuccessfully , to locate replacement parts so I managed to put the one I had back together and reinstalled it. Still working OK.
If you do break a valve spring or have to remove the valves be careful you do not lose the tiny ball bearings as they could possibly drop down the pushrod holes.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto12198.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto12199.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto12200.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto12201.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto12202.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto12203.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto12204.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto12205.jpg"/>
I cannot find the email I sent to John with the exact measurements etc. but the photos will give you an idea of what to expect. John tried all possible suppliers in US, Europe and Austrailia with no luck.
Hope this helps.
Further info: John(UK) also said that the rotators were not really needed and the valve spring could be replaced as usual.
Ron, the complete engine no. is SC93135EVR. As near as I can determine it is a 1955 or 56. Engine casting date 12-4 , Rear housing casting date 17-2-5
(quoted from post at 08:45:50 03/05/18) Ron, the complete engine no. is SC93135EVR. As near as I can determine it is a 1955 or 56. Engine casting date 12-4 , Rear housing casting date 17-2-5
I presume, then, that you are missing the serial plate by the steering wheel. :cry: The 12-4, if this is the number behind the generator, would be a casting date of February 1, 1954. The transmission casting date is February 17, 1955. There is a chance there was a warranty replacement of the rear end. So my guess is that you have a 1954 Fergie.
Although any owner could have bought a transmission or engine from a wrecker and do a swap.
I assume it is a gas only engine? Your fuel tank has only one filler cap?
Yes the serial no. plate is missing, it is a gas only engine. I am located in Belle River, ont.
Sorry Ron I sent you a typo error on the engine no. behind the generator it should be 6-12-4
(quoted from post at 16:39:43 03/05/18) Sorry Ron I sent you a typo error on the engine no. behind the generator it should be 6-12-4
Okay, that changes things a little. Engine cast December 6, 1954. That is more consistent with the rear end casting date. Your tractor was most likely born in March, 1955.
Could someone Please help me find the year my tractor was made and other information about (Bug) the name of my tractor. I was told that my tractor is a 1950 Ferguson.This is the information i got off the tractor.
Data plate on top of steering column s/n TO-43030 Harry Ferguson Detroit Mich along with a list of patent numbers.
Also on the left side bottom of the steering box HF TO-3550-A
Back of rear axles Left TO-4013 Right TO-4012.
Above the gear oil dip stick HF To-4024.
Right side of transmission HF TO-7006.
Left side of engine Firing order 1-3-4-2. Data plate below the firing order 1 4 3 8 7 8 1
011 011 20 30 2
Left side of engine Stamped raised letters Z120A600 the first 0 in the number is not raised like the other numbers its just stamped in the metal.
(All of the numbers and letters on the tractor are raised stamps, except on the two data plates)
Thank you for the help JCOutlaw
<image src="http://forums.yesterdaystractors.com/photos/mvphoto12938.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto12939.jpg"/>
(quoted from post at 17:29:19 03/15/18)
From the serial number you have a 1951 TO-20. It was built early in the year because they switched to TO-30 part way through 1951.
The Z120 also confirms a TO-20, 20 hp Continenetal engine.
