graham_in_NJ
Was reading Pomesters excellent post regarding the Sherman Combo install. I forgot I had one on my TO-30! However the shifter is stuck. Probably why I forgot about it. I pulled the steering box off to see if I could get it unstuck, but it appears that there isn't much I can access. The shifter handle moves slightly, so it looks like the innards are jammed up (not the shifter bound up in the casting bore). The tractor moves just fine, although I have no idea if it's in high, low or direct/conventional. I'm guessing conventional, as the speeds "appear" to be normal.
So....Is there any shortcuts to get the Sherman cover off to check the forks and see what is going on inside? I can get to the two fronts, but the rears may not be possible while installed.
If not, I'll have to pop the engine off to get the thing out to assess it...
Thanks in advance!
Thanks in advance!
