TO35 Separate differential from transmission
Finally time to fix it. As explained couple years ago I had water (condensation) in differential that froze and cracked the case and lid upon startup. Ready to split the differential from the tranny. Have lid off and trying to remove hydraulic pump. Got cotter key out of shaft, slid collar back to remove shaft. Still can't get shaft out. Almost but not enough play to remove. What needs tapped or loosened a 1/4 inch? I have service manual from YT. But no instructions on how to split tranny from differential. Don't want to damage tranny. Tractor is early 1955
is it possible the ice may have bent something ? i did that 10 years ago but my memory of it has long since faded.
I had to split MF 35 (1963 model) last summer, 2017:
Replaced HYD Pump and coupling:
Possibly pictures are of assistance?
If Coupling is seized on out put shaft of Transmission, separate Transmission, out put shaft and coupling as one unit from Diff:
Bob...
Thanks again to all. Got the pump out. Sump has lots of slime in it. Replacement case will start clean. I have read where YTers were discussing an oil filter screen in the lower part of this case. This tractor does not have it. Can I install one in the new case?
I might add plan to clean her up and paint correct green/gray colors. I purchased this tractor from FILs estate. He had for 8 yrs and I for 15. It was brush painted gray. Must have used a broom for a brush. Deep heavy brush marks, Painted over dirt and grease. Had to use a chisel to get paint/grease off bolt heads. A least it did not get rusty.
