TractorLinks.com
Show Parts for Model:
TO 20
ckain(mi)
02-08-2018 13:12:32
Is there a 'hand clutch' kit for TO20 ? Thanks
Tim PloughNman Daley
02-11-2018 05:04:16
 Re: TO 20 in reply to ckain(mi), 02-08-2018 13:12:32
I know I've seen hand clutches before but probably on a Ford. Try contacting Red Rock Mfg, (see LINK) ask for Phil, as he may be able to help you. The y make reproductions of the Dowden Foot Feed device that was used on 8Ns and up and I'm sure they work on Fergusons as well.
Tim Daley(MI)
ckain(mi)
02-11-2018 08:32:42
 Re: TO 20 in reply to Tim PloughNman Daley, 02-11-2018 05:04:16
Thanks Tim
Tony in Mass.
02-08-2018 20:59:36
Still got use of the right foot? I'd try to extend the clutch rod going thru the bell housing- a couple inches? Then cut and weld another pedal... might have to get a brake pedal out of the way... but who uses brakes anyway??? Might be less awkward to operate brakes by hand.... that's been done in cars for years...
miner09
02-08-2018 13:21:59
I've got a TO 30 with add on Sherman Live PTO that has lever on left side seat that's like clutch. It stops tractor and lets PTO run so you can raise lift or change gears. Is this what your talking about?
ckain(mi)
02-08-2018 16:04:37
 Re: TO 20 in reply to miner09, 02-08-2018 13:21:59
Not exactly. I am inquiring about a handicap, like no left foot. Need a hand clutch. probably can just fabricate the parts....
miner09
02-08-2018 18:58:30
 Re: TO 20 in reply to ckain(mi), 02-08-2018 16:04:37
There is a member of FENA that his Dad had to equip his TO35 but I don't remember how clutch was set up. Maybe someone will see this and help you. He also had a bracket on side of hood to hold his crutches. I'll look through my pictures and see if I have picture that will show setup. Good luck.
