Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: TO-30 front pulley
pomester
02-05-2018 15:45:44
just a suspicion, but I'm betting that the internal toothed lock washer is not original equipment - and it certainly wasn't tight against anything when it was in position -
I am in the market for the appropriate washer for this application if any of you have such an item available -
David
cdmn
02-06-2018 13:55:31
 Re: TO-30 front pulley in reply to pomester, 02-05-2018 15:45:44
Did you get it out? How did you do it? Was that a spacer plate that popped off?
I would have tried a chisel, air chisel, to back it out.
Or I would have welded a bar to the ratchet teeth. Could grind them
back to normal afterwards.
Richard L
02-05-2018 16:15:34
The reason the water pump is tight is because there were suppose to be 3 nuts holding it on. Remove one more nut and you should be in better shape.
Richard L
02-05-2018 16:11:06
There is suppose to be a starting jaw washer behind the crankshaft starting jaw. The Ferguson part # you are missing is 1 750 149 M1
