Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: TO-30 engine refurbish
pomester
02-04-2018 14:31:20
Here's a little something I've been setting on for 3 years -
I'll have that area open shortly... should I install the Sherman?
How would I locate the shifter hole? How would I drill the hole? Except for that aspect it doesn't look like it would be too bad of a job....
Kirk-NJ
02-05-2018 15:50:22
 Re: TO-30 engine refurbish in reply to pomester, 02-04-2018 14:31:20
Sure slap it in. Did you have it apart? Is it good to go? Don't see many ferguson sherman. I pull this one out of a TO30. It's a ford case that has been altered. Top, one on the left. The back of the Case also altered to fit. If someone needs it to fit the ferguson and has the ford case I would swap.
I could tell you where to locate the hole on the ford. I guess it's best to put it in and take measurements. Drill a small pilot hole before you use the holesaw to make sure you are on the money.
ernied
02-04-2018 15:03:49
Lay a straight edge (carpenters square) across the head; I am betting you will find it warped. How was the oil pressure? I am
betting the coolant wiped out the seal and maybe a bearing or two. Long time ago I saw a drilling template for a Ford, but don't
know about a Ferg 30. Cast iron will not drill bad. Pilot hole and good sharp bits.
