Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
TO30 rear axle inner seal?
Kadbow
02-02-2018 09:27:49
A new to me TO30 that I am doing some work on. I have the rear axle pulled out and am ready to install the new inner seal. Which direction does it go? May be a dumb question but I just want to make sure I put it in right. It has a solid face and a seemed face. Thanks for the help.
Kadbow
02-03-2018 10:56:30
 Re: TO30 rear axle inner seal? in reply to Kadbow, 02-02-2018 09:27:49
Thanks for the great advice.
Kadbow
02-03-2018 05:25:34
Another question, the axle shaft is a little rough where I assume the seal sits/rubs on the shaft, will the seal seal if the shaft is not perfectly smooth?
miner09
02-03-2018 07:46:53
 Re: TO30 rear axle inner seal? in reply to Kadbow, 02-03-2018 05:25:34
Take fine emory cloth and smooth it.
Tom h.
02-02-2018 14:59:51
As miner says lip or opening towards oil source. Learned the hard way with a rear main seal and spent the rest of the day respliting the tractor to install a new one.
miner09
02-02-2018 13:11:16
The lip or open rubber goes to the oil side. You can see the spring inside if you pull lip back a little. Put this toward the oil. Hope this helps. Just a way I always look at it.
