TractorLinks.com
Show Parts for Model:
Tea20 throttle lever installation
kaesark
01-26-2018 18:09:12
What is the correct way of putting back together, doesn't want to go in with spring set in place as it won't clear the bottom to sit in hole. Thing is driving me nuts.
Patch700
01-26-2018 19:20:18
 Re: Tea20 throttle lever installation in reply to kaesark, 01-26-2018 18:09:12
Remove cotter pin , allow spring to slide where it wants... then slide shaft up and into position... once itís in the guides THEN you can slide spring back up and install cotter key. Otherwise the spring goes into full coil bind before you have enough room to get the shaft high enough to slide into position.
Good luck.
kaesark
01-26-2018 19:55:21
 Re: Tea20 throttle lever installation in reply to Patch700, 01-26-2018 19:20:18
How do you manage to compress spring which needs to be fully compressed to get the Cotter pin in.
Patch700
01-26-2018 20:06:16
 Re: Tea20 throttle lever installation in reply to kaesark, 01-26-2018 19:55:21
Zip ties .... cut em when the cotter pin is in place.
