Rocky Field Farmer
Just bought a Massey Ferguson that appears to be a 202 with loader. The plate is missing under the steering wheel. The plate on the engine is a Z134. The guy I got it from had done a lot of tinkering on it and so far I have replaced the points and plugs. The new condenser I got with the points has a welded mounting bracket and the distributor plate has a loop for a smooth condenser. He had installed new wires but they are carbon core (heading out in a little while to get copper core) he also managed to crack the rotor button so I replaced too but couldn't get a new distributor cap, will be picking up with the wires. I am going to jump straight to the coil to see if that helps, if not I will replace the coil also. I looked inside the carb and it looked like the venturi was installed wrong. Marvel Schebler carb. It is about 10 degrees outside and if I get this engine to run and run smooth at this temp it will be amazing. IF my fixes don't work I will be asking questions. Thanks in advance
