Hi
I am having trouble getting a nut to go onto a bolt seems that the thread is getting stripped on the nuts that I have tried thus far.
The bolt in question is on the rear axle case housing on the flange that bolts onto the rear of the tractor. I assumed these were a UNF thread on one end where the nut goes on and unc on the end of the bolt where it screws into the tractor chassis
These studs/bolts are very close to the casing which would make it very hard to re threat in place, I may be faced with having to drill it out.
Cheers
Cheers
