William Fissell
TO-35, horrible metal-on-metal screech from the front
Crank puller has a crack in a spoke and I bet that helps nothing.
I pulled the timing cover and the governor is OK. The aluminum gear that drives what I assume is the oil pump is beat up looking, and has enough fore and aft play that it strikes the inside of the oil pan.
About to pull the pan and look; commensta dn advice welcome.
BIll
BIll
