Reassembling the front spindles and axle having had new bushes and thrust bearings done, when fitting the radius arms I decided the old bolts were looking a little worse for wear so headed off to the engineering shop only to be lost in a sea of Nuts N Bolts a totally mind blowing experience to say the least.
Anyways I could not find an exact replica of mine however did find some of the same length and diameter and are High tensile rating of 8 (super tough im told).
The head is smaller on the new bolt as is the nut. Should this be a problem given the strength of the new ones. The other issues common to the original and replacement is that the thread is vulnerable to wear as it passes through the eye of the radius arm.
Any thoughts out there.
