Hi
Thought I would check on the play of my Fergys front Hubs, there is some up and down play in one of the spindles so will replace thrust bearing on that side.
The other issue is that neither hubs contained any oil but appear to be well packed with grease, my question is then is this an acceptable scenario or should I overhaul so as to get to the point where the hubs contain oil without leakage.
Thanks and Merry Xmas
