Delawaresurfman
I've posted before about this issue. The starter wire
going from the battery to the starter switch on the
transmission housing is getting hot. The switch post
also gets hot. The thought is to change out the
switch. All connections have been cleaned good
twice. Today I noticed that the wire going from the
amp gauge to the starter switch is under the battery
cable wire on the switch. I'm going to change it
around and put the battery wire directly on the
switch post and the amp wire ontop of the battery
eye ring. Do you think it will make any difference in
the amount of contact and not get hot? Should I just
order the switch? Thanks,
