when setting up to plow with a TO35 tractor,
do you set the inside of the front tire straight with the inside of the rear wheel,
I have my front tires set one notch or bolt hole out, so the inside of the front tire is about 2" farther out than the inside of the rear tire.
I see videos of tractors plowing and sometimes it appears the tractor is trying to crawl out of the furrow.
any thoughts on tires width settings?
