TractorLinks.com
Show Parts for Model:
6.50 x 16 vs 6.00 x 16 Front Tires
guysradios
11-13-2017 18:47:16
I came across a set of new 6.50x16 tires cheap cheap that I want to use on my TO 30. Has anybody used them in place of the standard 6.00x16 on the front of there Ferguson ? Any issues? They look about a half inch taller, but not much wider than the 6.00s. Thanks
Boss Hog
11-17-2017 09:16:12
 Re: 6.50 x 16 vs 6.00 x 16 Front Tires in reply to guysradios, 11-13-2017 18:47:16
I have 7.50/16s on the front of my MF35. No problems with rubbing.
wellmax99
11-15-2017 15:53:59
picture of my TO35 with 600-16's on the front.
am sure the 6.50 would not make that much difference.
if they are cheap go for it.
Leroy
11-15-2017 06:32:07
Smother ride as more surface touching ground. And should have no problem with sidewall clearance unless you are in heavy mud then you would also have that with the 6:00 tire. I had a 30 years ago and would not mind having one now but no use for anouther tractor.
glennster
11-14-2017 17:26:06
i have 6.50-16 on my to 20, i like em
guysradios
11-14-2017 03:51:37
Thanks for the responce
miner09
11-13-2017 19:14:51
I've used them on TO35--F40 with no problem. They will be closer to the spindle housing but not rub.
