Dearbourne field cultivator
BuckeyeDan
New User
I am new to this fourm so please bear with me. I recently acquired a Dearbourne 10-95 cultivator in relative good condition. Need to know any info you can give me about it and if it has value beyond scrap. Bought it to go with the TO20 I am working on. Also need a coulter with hub assembly for AO-28 plow.
Well, if and when you need a cultivator, it is worth a lot more than junk. Most Dearborn marked implements were sold at Ford dealers, so you should post this on their forum too.
As far as a coulter.... until your ground is worked up often enough to let a coulter sink in, you are just as well off without it. They are around, usually in good shape, cause they were removed... for different reasons.... so don't worry about it.
Welcome to the forum
