Hrobertson1
New User
Hi all, hoping to get some help. I bought a 1952 TO30 with a wagner loader, it sat for many years. Towed it home, fogged cylinders, changed all fluids, emptied and cleaned the gas tank, replaced plugs, wires, , resistor,switched to electric cap, new wiring, battery, carb. Fired right up, was running great, hydraulics were working, pto was spinning, life was good..... then I turned it off. Started it back up and started running rough, stalled out. I cant keep it running. I bought the "better version" carb off of here. http://www.yesterdaystractors.com/Ferguson-TO30_Carburetor-New_12522B.html
When I pulled the air intake hose off it was full of fuel (about half a quart). I tried to find the screw settings for the carb here to see if they were backed out too much but couldn't find anything. I bottomed them out , then back out 1 turn, didn't make a difference. idling high, wont stay running unless the chokes on. I spent about an hour trying to adjust the screws in and out, didn't make a difference. Any ideas or help would be greatly appreciated.
Thank you,
Henry
Thank you,
Henry
