Make that First and second gear
mhadavi
It seems to go into the gear position but no response. Third, fourth and reverse all work as should
Andy
I have seen several Fractured / Brocken / Bent 1 & 2 nd gear shifters.........:(
In 1975 I had to fabricate a 1&2 gear shifter....all steel and still in Transmission on daily user....
Item # 27
Bob...Owner operator TEA-20
Thanks for your reply on question about 1&2 gear.
I have a shop manual for the tractor and it does not show the steps for replacing the fork. Do you have any suggestions?
Here is how I proceeded with the Transmission (1&2 shifter) I had to repair.
Disconnect battery and remove:
Drain oil from Transmission:
Removed TOP of Transmission cover, Steering Column, and Dash as one UNIT:
Make sure you DO NOT LOOSE or drop SPRINGS,BALLS etc, that place shifting shafts into proper position:
VERIFIED problem....?
Split ENGINE from TRANSMISSION at BELLHOUSING:
Perfect time to inspect CLUTCH and associated parts, Throughout Bearing, Running clearance on Bearings of Transmission INPUT SHAFT:
