1955 TO35 Major Miss
Wonewoc
New User
I have a 55 TO35, 6v system, new plugs (Autolite 3116), points, wires, and condenser within the last 20 hours of run time.
It had been running great. Then it developed a miss upon cold start which would clear up when warm. Now it has progressed to where it will run smoothly for a few minutes or seconds then go into a sputtering, coughing fit. It will die completely, then catch and run again.
I thought it may be due to bad gas so I drained the tank, sediment bowl, and float bowl. Refilled with fresh gas. No change.
Any ideas?
Thanks, Joe
I would say it would be a good idea to pull the plugs and see
what they are telling you...
Granted 20 hours isn't a long time on a tune up , but it can be
a short enough duration to foul one or all the plugs to some
degree.
If they are black with heavy soot then you know it's possibly a
flooding issue (carb out of adjustment or plugged air filter)
If they are oil soaked you may have a bad cylinder and just
need to clean or replace that plug often.
If the plugs look to be from a lean condition then start with a
gas flow test at the bottom of the carb bowl..
lots of flow , possible carb or float adjustment issue.
Missing can occur from both lean and rich conditions as well
as weak spark....
missing with black smoke is obviously a rich condition..
Missing that clears up when choke applied is obviously a lean
condition.
Good luck , let us know what you find.
Some points are bad to do this. Try a new set even if you just replaced. I buy point
from Sparex and never have trouble. Think this site may carry same.
(quoted from post at 13:33:35 10/02/17) Some points are bad to do this. Try a new set even if you just replaced. I buy point
Checked point gap. Was OK. Decided to put my old condenser back in. Problem went away. It's back to running great.
Thanks guys for all your input.
