John Deere D
Tractor TEA-20 S# 182991, Engine # S105046E has a Faulty 6 VOLT Starter / Components ?
I have the Original SERVICE MANUAL (6 VOLT) and shall dismantle STATER DRIVE:
Starter "MOTORS" like it always has, now the "SPIRAL DRIVE" no longer turns with the ARMATURE?
Instructions indicate a "RUBBER" component that I believe may have failed?
ARROWS on Picture, indicate POINT were SPIRAL DRIVE and ARMATURE are NO LONGER rotating as one unit:
This is a 6 VOLT arrangement, my parts TEA-20's are all 12 VOLT Starters.....
The original 12 VOLT starter engage the FLYWHEEL from the AFT face of the FLYWHEEL / Ring Gear, were as the 6 VOLT engages the FLYWHEEL / Ring Gear from the FWD side of the Flywheel:
I could exchange the FLYWHEEL, so as 12 VOLT starter functions......not going to happen:
Would someone have a contact as to purchase new STARTER drive Components for the 6 VOLT Starter as per pictures?
Bob..
Bob..
