First off thanks for any information that you guys can give me to help me out. Ill give you some information about me and how i ended up buying this tractor. For the past 12 years ive lived a few blocks from my uncle and cousin which live next door to each other. We raced 4 wheelers together, mini sprints and now onto autocrossing miatas. Ive worked on plenty of 4 wheelers and dirt bikes amd have taken them down to the frame and powdercoated them and made them like new again. Recently my uncle passed and so my cousin was going to sale his tractor that hes had for years and years. Hes helped me out tremendously over the years with this tractor at my house, spreading gravel and moving dirt and things like that with it. I really hated to see it leave the family so I emded up buying it. One of his dreams was always to completely go through this tractor and rebuild it. I've decided to take this on in my little shop for however long it takes. He always said it was a 1952, he was born the same year. I believe it has z129 continental engine in it so i think its a t030. It appears to be leaking fluid from the left rear hub and think the front wheel bearings are bad. The tractor does start and run fairly well with some smoke but not to bad although it does tend to foul plugs over extended periods. Im still trying to find what types of fluids that i need to put where. Ive never owned a tractor but would like to learn how to check to e sure that things like the tranny and rear end have the proper fluid levels in them. I believe i read it takes 5 quarts on 10w40 and will have to find out what oil filter exactly to get. Believe someone took the brake linkages off at some point but my land is fairly flat so shouldnt be an issue. Thanks for all the help
