Hi guys just wondering if anyone knows were i can get a drawbar for the rear end under
the power take off. Is the drawbar held in place with a factory pin? Can anyone send me
a picture? I need someone who will send to ontario canada or if there is someone in
ontario. Thanks for all the help
Try these two Canadian suppliers:
(1) [email protected]
(2) Mr. Stephen Radford from Ontario Used Tractor Parts, the phone # is 519-523-4922.
There is a simpler version as well .
Mounted onto the differential housing by four studs . The bar itself pivots and is removable once a pivot pin is drawn .
Yes charles that is the same unit i have on my
tractor, my i know the year of your tractor and do
you think the part is stock ferguson? And does
ypur tractor have a hup hi/ low gear?
Hupp transmissions are very rare in Australia Lornadraper , restricted most likely to privately imported examples .
My TED20 is a 1952 model Australian delivery tractor fitted with a Standard Motors petrol engine . This swinging drawbar is peculiarly Australian and was made for tractors from about 1950 .
Ron's drawbar is an authentic accessory used on tractors earlier than this , they are highly sought after by collectors here as they are relatively scarce .
(quoted from post at 18:16:48 09/15/17)
There have been a few modifications made to yours Ron , it would be easy to return it to its original state .
Ha,ha. I did not even notice. :) I "stole" that photo from the net, so I could give an example. Since my tractor is under repair, I could not easily get a photo. So, mine does look like yours. :roll:
