TractorLinks.com
Show Parts for Model:
stabilizer bars
kleine39kermit
09-11-2017 11:26:01
I bought 2 stabilizer bars 230042R Mine are gray not red with 31 1/2 hole spacing. I'm trying to attach a shredder to the tractor but the stabilizer bars are 1/4 inch short or if i Connect one the other is 1/2" short. Are the mounting brackets under the axle slotted to where you can adjust them or the hole where the stabilizer bolt goes into the bracket? Mine are so tight I can't get either loose. The mounting bracket is held on by 2 long bolts which also hold the fenders.
Jeremy in DE
09-12-2017 05:52:37
 Re: stabilizer bars in reply to kleine39kermit, 09-11-2017 11:26:01
Just a small addition to the comments.
I bought an adjustable stabilizer bar. Similar in construction to the top link. I put on the fixed length bar, then adjust the other to fit. Then I tighten it a couple turns to take out all the slack so my implement will not move side to side at all. Works great.
Of course, this only works if the pins on the brackets are exactly in line with the pins on the lift arms. And, the vast majority of the time, one stabilizer bar is enough for me. But when I want to, I can take out all side to side movement entirely.
maxwell99
09-11-2017 20:51:00
Another thing to check on your tractor cutter set up,
The stabilizer bar brackets may be set up for a Ferguson implement, Check the spacing of the lower hitch pins on your Ferguson plow or disk,
If your cutter is an aftermarket implement the spacing may be different, example wider
I have a Ferguson cultivator, the stabilizer bars fit perfect on this implement, but on my house brand cutter, only one fits as the lower pins are spaced wider,
The stabilizer bars would have to be different length, if I wanted two on the cutter,
The stabilizer bar situation can get a bit frustrating using different brand implements,
marloweg
09-11-2017 20:07:12
the pins for the stabilizers MUST be in line with the pins for the 3 point hitch if not parts will fly . you only need one stabilizer bar not two
kleine39kermit
09-11-2017 19:51:01
Thanks I'll Try to loosen the 2 fender bolts.
jamstra
09-17-2017 09:36:57
 Re: stabilizer bars in reply to kleine39kermit, 09-11-2017 19:51:01
I agree with marloweg - stabiliser pins must be directly aligned with the mountings for the lower lift arms, if course you are using a genuine Ferguson stabiliser that is the correct length! I've had recent experience of removing fender bolts - couldn't move them with a cheater bar on a socket, but they came relatively easily with an electric impact driver, working back and forth with plenty of lube - the bolts are good quality, and mine were actually re-usable after having been pointed down into the muck for 50 years! Good luck.
Jim
kleine39kermit
09-11-2017 19:49:24
Then they would be 2" to long.
wellmax99
09-11-2017 18:44:25
the attachment brackets under my axles have slots, so they can be adjusted maybe one inch.
TO35 Ferguson. but you will have to at least loosen the fender bolts to find out if yours have slots.
however, I always just use one stabilizer bar with my cutter, so if it's a bit short or long it will not matter, the lift will work fine.
as long as you are not backing up, using your rotary cutter to knock down young trees or buildings, you should be good to go.
one stabilizer bar will keep the cutter from coming over and slicing up your tire.
Indy4570
09-11-2017 16:01:26
when i bought mine I saw 31.5 and 33.5 offered, maybe you need the longer set
miner09
09-11-2017 19:22:00
 Re: stabilizer bars in reply to Indy4570, 09-11-2017 16:01:26
Longer set is for High Crop tractor.
