TractorLinks.com
Show Parts for Model:
starter woes...
Indy4570
09-10-2017 10:43:17
Ok so I had two broken springs in the TO20 starter. so I look around and buy a set of springs with bushings and brushes, they come, all good. But the springs I got are wound in reverse of the ones in my starter? so maybe they fit some starter that rotates in the opposite direction? need some help to find the right springs.
DC1
09-10-2017 16:49:13
 Re: starter woes... in reply to Indy4570, 09-10-2017 10:43:17
need a mirror to see the gauges.
Indy4570
09-10-2017 15:54:43
"negative" as in the picture, not polarity ;) I think farmals had the starters behind the flywheel, so the starter would rotate in the opposite direction to turn the engine in the same direction, or do I need more coffee? O.o
Indy4570
09-10-2017 15:44:59
the starter would be turning in the opposite direction, I will try to get some pics, I am not aware if all tractors engines rotate in the same direction, I suppose if the starter was installed from the rear of the flywheel it would have to rotate in the opposite direction to turn an engine in the same direction. I simply looked at the springs and they looked to be the same as I needed. the mistake was mine.
Indy4570
09-10-2017 15:41:13
haha, well I assume if the springs push down in the opposite direction meaning the kit I got was for a different model than the ferguson :P
Indy4570
09-10-2017 13:57:35
I have the starter from my 48 TE20 in it now, I ordered another set with the same springs but wound in the opposite direction this time, lets hope they didn't reverse the negative :P
Bruce(OR)
09-10-2017 15:37:30
 Re: starter woes... in reply to Indy4570, 09-10-2017 13:57:35
What's reversing the negative have to do with anything? You mean if the polarity is reversed, the engine starts and runs in the opposite direction?? So going from pos ground to neg ground makes it runs backwards? This means the transmission is now reversed. 1 speed forward and 4 reverse. This is getting to be fun. I suppose then you have to run the 3 point on the front of the tractor so you can plow going backwards. Better turn that seat around while your at it to.....Yep! Big wheels on the front and small on the rear. I suppose now you have a front wheel drive tractor and steers from the rear. Told you this was getting to be fun. Just think, now you have dual lights in the rear and one in front. Running boards might need to be extended a bit....
Bruce(OR)
09-10-2017 11:57:56
Mebbe your starter is the oddball and not the parts. . . . . .
Search/contact the below seller IF you are unable to find what you need on this site,
Bruce(OR)
09-10-2017 13:41:10
 Re: starter woes... in reply to Bruce(OR), 09-10-2017 11:57:56
Wayne, from the above mentioned site, used to own a TO-20.
The wife's TO-20 showed up with the starter literally hanging out the side of it dangling by the starter cable. Good luck with yours.
