TEA20 Rocker cover to manifold breather pipe
sqr2000
New User
Hi
I wonder if anyone can help, I am working on a rebuild of my te-a20 and I am missing the connector which connects the rocker cover breather pipe to the inlet manifold, it is the
only part I can't find, I have searched all of the forums and can find discussions but no availability?
They are notoriously difficult to find , often they are discarded because the tube looks to be flattened , but this is their normal appearance .
There are two sorts , one for the TEA that is placed on the outside of the manifold and the TED version that runs a convoluted path through the manifold tubes .
This is one I made from copper pipe , it is a TEA style fitted over a TED manifold .
I have never seen the part you seek sold by itself , the fitting you need can be made from stock brass fittings available from any plumbing/ gas fitting shop . A brass 1/2 inch male adapter into a 3/4 inch male iron union and some creative silver soldering and a small jiggle pin .
The easiest thing would be to source an entire tube from a breaker's yard .
Hi, Yes, thats it, It's items 4 and 8 I'm after, I have the pipe and top banjo bolt.
I will pop to the plumbers shop today to see what they might have.
Simon
