[b:5d19f0b1d1]Well I want to thank you all for the input and post you put here, got the TO 30 back running again. I have a couple issues and once again need to pick the thoughts of the Knowledge base. My first question is when i start the tractor my ammeter pegs a 30 pn the positive side, now it use do this then eventually drop to 0-5 amps now it does not just stays at 30 any ideas.
Second is when I start the tractor the starter drags but if i hit the choke it starts right up, could this be a timing issue or starter issue?
Last is it worth the investment converting the starter to 12 Volt instead of using the resistor to convert. I run 1/0 cable positive and negative comments, thank you.
[/b:5d19f0b1d1]
[/b:5d19f0b1d1]
