The TE20 I bought last Sunday had decent oil pressure, about
25 PSI warm, but the oil was dirty so I wanted to change it.
I didn't even change the filter (explanation below) I just
drained the oil and put new oil in. Now it has NO oil pressure.
I took the gauge line off and rolled it over, no oil coming out.
I tried priming it through the gauge line hole because I read that
on here, no luck with that. I even tried adding an extra quart of
oil to cover more of the pickup, but still no oil pressure.
Suggestions?
Here's the reason for not changing the filter yet.
Someone has welded the cover into the oil pan so I have to pull
the pan to change the filter. I didn't know this was done and do
not have a pan gasket on hand. Once it gets here I'll change it.
Suggestions?
