MF 235 PTO shift
On my 235 I have a problem. The lever moves back and forth but the PTO does not engage. I assume the fingers on the inside moving the collar to engage the PTO have broken off. I hope I am on the right track. Is there a big problem removing the side plate to look things over? Thanks, Stan
No just park tractor tire on block-slope- or jack up so oil will not run out.Don't have to be up very high.Just watch close as you remove cover in case something comes off.It has a roll pin that hold lever on.
